1 - 5 of 5 Posts
Is the FI system something that has a useful life, and the must be replaced? or will it run indefinitely, assuming fuel filters are changed regularly? How much does does it take to install a MPFI system in a 2001 'stro? Assuming good mechanical abilities.
Administrator
Nothing mechanical will run indefinitely. Cost depends on which parts you buy and where. Probably about $300 to diy.
My 2000 went to 210K.. then failed miserably
Discussion Starter · #4 ·
Thank you. Does anyone know what flat rate book is for a mechanic to swap out the FI system?
1 - 5 of 5 Posts
