1 - 3 of 3 Posts
120000 MILES pulled dist cap rotor where screws go through were broken where the rotor screws to dist is cracked,bought used dist still no staet,when turns over acts like its out of time will turn over and then stops like its out of time,did this before new [used] dist was installed,drove home 1 nite went to start next morning and wouldnt start ,,,,,,,can anyone help how do i set timing? is there a special way to install dist? please help ive had several astros this is first tim any problem like this,,,thanks doc
If it did this before you replaced the distributer, the dist is probably ok. I'm thinking timing chain, like it jumped a tooth.
Can you take a compression test?
1 - 3 of 3 Posts
