1 - 13 of 13 Posts
I wanted to thank everyone's post(s) and picture(s)...have proven invaluable.
I recently bought my 4th Astro/Safari van. I thought I would posts pictures as I fix her up, since everyones' pictures helped me a lot in the past.
Discussion Starter · #3 · (Edited)
After purchase, I drove her home 2 hours. Drives nice, but I took back roads and never went over 40mph. These are pictures taken by the previous owner that she posted in the classified. Located in Pennsylvania, so she is rusty/rotted. I hope some of my 'fixes/photos' will help others, as others' threads, has helped me.
2002 AWD with towing, rear AC, rear heat, plus standard options. 151,000 mileage.
Tire Automotive parking light Wheel Automotive side marker light Car
Car Automotive parking light Land vehicle Vehicle Tire
Discussion Starter · #4 ·
I was midway through this first repair, and decided to share...radiator support! At first, I tried lifting the body, but pulled the frame up with it. It worked, on my past vans. This time, I had to chain the bumper rails to the bottom of my engine lift, in order to raise the body to proper height.
Tire Wheel Automotive lighting Automotive tire Hood
Motor vehicle Tire Automotive tire Hood Automotive lighting
Motor vehicle Automotive tire Wood Wheel Vehicle
Discussion Starter · #6 · (Edited)
I knew what I was getting into. This is only the beginning, much more damage will be shown.
Note: i just found out ODB port power is same circut as the rear cigarette lighter power(blown AUX fuse). I also have the front cig lighter stays on(this is likely normal) but the rear heat/rear air blower power remains on as well, not sure why, could drain my battery one day.
A "Heart Felt Welcome" to you is in order, but not Automatic...
LOL - "NO PROPERLY WORKING CIGARETTE LIGHTER"... that's it, game over, ditch it, no way, hands full, see ya' later, rip off...
Rust on it too?
Looking forward to repair pics - we Live For Pics ( except the upside down blurry ones ).
Discussion Starter · #9 ·
Welcome! Im partial to the color, i find it hides the rust on mine
I was shocked to find spray paint costs $18! But Walmart saved the day, with matching paint to boot! The paint is very close, depending on which viewing angle, maybe a different primer, can get it closer. I use tape to prevent overspray(notice straight lines), this is just a quick paint over rusty spots.
Automotive parking light Automotive tail & brake light Tire Wheel Car
(Krylon 7519 gloss classic red closely matches 2002 Astro paint code 307D)
I was shocked to find spray paint costs $18! But Walmart saved the day, with matching paint to boot! The paint is very close, depending on which viewing angle, maybe a different primer, can get it closer. I use tape to prevent overspray(notice straight lines), this is just a quick paint over rusty spots.(Krylon 7519 gloss classic red closely matches 2002 Astro paint code 307D)
Oh hell yes
I have numerous paint issues to resolve!
Discussion Starter · #13 ·
Didn't as much as I wanted this weekend, cut out some of the rust and made some brackets to bolt into bushings....
Textile Red Gas Wood Art
.....then I reassembled the front end to check height and alignment. I probably will make new pieces, using sheet metal to replace what I cut out. The brackets will have holes drilled and bolted in, I'll have to wait for new bushings in order to finish.
Wood Motor vehicle Bumper Fender Automotive lighting
Motor vehicle Automotive tire Automotive exterior Bumper Gas
1 - 13 of 13 Posts
