Here is the one you’ve been looking for
2004 Astro 4WD – PROS:90K miles – no major dents – zero to minimal surface rust only on rear wheel wells – Everything works as designed – Have all removed rear plastic body parts incl rear seat.
CONS: little dings - Super fine shimmy btwn 50-80 MPH (Gear swap guy says it’s because Driveshafts are spinning faster)
- Protune lift kit – front Lifted 2in body pucks - shackles in rear
- JOR 4WD setup w/ 2000 S10 transfer case
- Nitro 4.11 gear ration swap front and back
- Eaton Detroit TrueTrac locker in rear
- (2022) balanced and extended rear driveshaft (needed due to lift)
- (2022) balanced front driveshaft
- (2022) 5-year warranty front wheel alignment – Big-O-Tires
- (2021) all front suspension parts done – drives tight
- (2021) AC Delco tuneup incl AC Delco distributor complete assembly
- Class 4 trailer hitch
- Towing Brake Controller
- (2019) (larger) radiator w/ Electric cooling fans (2 fans) – Custom shroud
- (2021) Transmission Cooler - Hayden 679 Universal 11” Rapid-Cool Add-On Transmission Cooler
- (2019) MagnaFlow Catalitic Converter – MAG 59956
- (2019) MagnaFlow Exhaust – MAG 11225
- (2022) New Interstate Battery
- (2022) New Axle Shafts in rear
- (2021) New Timken front wheel hubs w/ new bearings and calipers
- (2020) New brake lines
- (2022) New brake ABS module
- ProComp Extreme Wheels
- (2021) Falken 2Wildpeak AT3W all-terrain-tires 235-70R-16
- (Extra) Original Aluminum Wheels w/ BF Goodrich KO2 215-70R-16
- KilMat complete coverage from rear up to cab. Haven’t done cab area
- 2ply ceramic infrared ultimate tint on all windows incl windshield (80%)
- Double Din Pioneer 5200NEX receiver w/ Touch Panel, Apple Car Play, navigation, etc…
- 2 rear view cameras. One mounted for towing hitch in bumper
- New front speakers
- Custom Subwoofer
