Found a complete LQ4 (iron LS truck block w/everything including the computer) to drop into my van. Been reading threads so much here...appreciate all the info on the board. Thank you.
Still a few questions as I'm gathering all I (believe to) need in order to make this as seamless as possible. Appreciate any insight here.
Have an '05 AWD that's mint condition and want to retain all the stock functionality. Considering a cam since I'll have to have it tuned anyway and eliminating the rear O2's to go with and X-pipe and duals but that's irrelevant to the concerns below.
A/C: Have to relocate the compressor to make it work on the new LS block. Checked the Alan Grove site and those brackets all refer to using a Sanden A/C compressor. Any experience here? Can I fit my compressor to their bracket or am I now running A/C lines to the donor's compressor?
Clearance: Are you guys all using 2" body lifts? Prefer to not do a body lift but need to know if it's necessary to fit the LS w/truck intake under the dog house?
Oil pan: Has anyone had success with a pan fitting into an AWD without fabricating one?
Differential bracket: Only seen one mention of this. What have you guys done up front to fit the LS block?
Intake: Concerned there isn't enough intake volume, especially once a V8 is in there. Thoughts or solutions?
Fuel: Is the 4.3 fuel pump enough to feed the V8?
Sooner I get the parts together, sooner it's done.
Thanks.
T
Thanks.
T
