A month with a couple thousand miles and several tanks of gas later and I can say, it's done! I think most of the hurdles we ran into were put into the thread here. Everything works exactly as it did originally; cruise, gauges, A/C and the rest are all functional. I still recommend a 3" body lift to anyone who might want to do this. By the time you get to putting the A/C together it will make life a lot easier. Spark plug changes and other maintenance would be easier, too. I went 2" and it was just enough to scathe by.
There were a bunch of expenses I hadn't planned on. The new transmission, transfer case and drive shafts weren't in the original plan. Overall, it makes sense to have done them seeing as it's a whole new drivetrain. Plan to add a tranny cooler, too if you don't have one. I'll post if/when the differentials let go! If you plan on doing this swap you should also plan to install a 1" radiator and (I suggest) e-fans along with it. It also made sense to do any brake work while in there because going straight and fast also means needing to slow down at some point. A front end alignment is necessary when it's all back together, too.
I couldn't resist the temptation build it up while in there. Wound up with a custom cam, lifters, rods, tuning, 2800 stall converter, FLT (overkill) transmission, custom driveshafts with an aluminum rear driveshaft and a front driveshaft with a GM 1500 yoke. The exhaust is true duals with no cats and to Woodbutcher, it's not a problem until it's a problem
(I'll let you know next June how that goes)
This thing absolutely rips! It jumps onto the flow of traffic on the highway from 30-90mph in a few seconds and it really gets a lot of attention doing it. It's pretty funny to see the looks on other peoples faces when a lifted Astro tears up the road. I like it. A-lot!
People said I was nucking futs to do this project. Now, they're all totally into it. People comment on it every day and say things like, "I was never a van guy...that thing is awesome!" and "What is that? Is it new?". lol I love this rig!
:thumbup:
