'83 Safari conversion 4.3 102,000 miles
The engine has been down in power and knocking a bit. I've had it just over a year. I figured first I'd change the air filter, cap, rotor, plugs and wires.
After looking under the rear cover I realized I'd have to have the hands of a five year old with the strength of body builder to get the plug wires off and the forward plugs changed. There is no clearance. How do you get in there? I looked through the paper work I had and found that the plugs had been changed at 78,000 miles so I just changed the blackened air filter, cap and rotor and decided to see how it ran.
No difference. OK, so old school kicked in and I retarded the timing. I marked and spun the distributor 1/16 of an inch clockwise to see if it would help the knocking and bring any power up at all. The engine idled really rough and chugged and loped and then flooded when I tried to restart it. I put the timing back exactly where it was and the idle is the same. On the road, it runs the same as it did before I did any work on it but it won't idle. If I don't give it a little gas, it will eventually die.
I disconnected the battery and let it sit overnight, reconnected it and drove it about 15 miles to see if the computer would relearn and get the idle back. No luck. I checked it for codes even though the engine maintenance light wasn't on. No codes.
Any ideas on the idle, knocking/pinging and loss of power? It's not like it's totally gutless, it just doesn't have the same get up and go it did....and how do you change those forward plugs?
Thanks
Thanks
