Hello,
I have a 92 astro with 190k miles. The tranny went out and i had it rebuilt. After reinstalling the van shifts at a way too high rpm and then jumps/lurches, sometimes with kind of bang you can feel, into the next gear. If i hold the gas pedal at a low rpm the engine rpms go real high and the van stays in first until i let my foot off the gas. This happens in every gear although not nearly as bad as from first to second. If i give it a good amount of gas, maybe half throttle, it shifts much much smoother. but if i try to drive slow and normal it bangs/jumps into gear.ive already had a u joint go bad because of whatever this mysterious ailment is. Ive already readjusted the tv cable and dont know where to look to next. any ideas?
