started as a horrible overheating issue.
checked a few things and found that the radiator was plugged from the front. looked like a beaver dam across the whole bottom half. so i cleaned that all out and put in a brand new thermostat just for kicks. nothing helped. so i took out the radiator and had it tested. it was ok. so the last thing i could think of was the water pump they are only 35 bux so i picked one up. the engine is a lot quieter but still overheats in the same way.
i almost forgot before i started messsing with things i bought a backflush kit and installed it and flush the hell out of it. and have many times since.
so i unhooked hoses and made sure they werent all plugged up blew water through them they were fine. blew out heater cores everything flowed good. i just took out the thermostat to try running the car without it and see how things go. i've nothing left to try after that lemme know anything you can think of.
thanks all
jeremy
p.s. it's a 1992 vin z safari with front and rear heater setup tbi
thanks all
jeremy
