1 - 5 of 5 Posts
Never had any problem till now, all of a sudden engine will not start,engine cranks, no fuel pump prime,head lights do not turn on ,fuses are all ok, coud it be the fuel pump relay or some elecrical problem,what do i look for.馃槹馃槹馃槹馃槹
Administrator
I would start at the fuel pump connector, are you getting power there when priming/cranking?
Edit: missed the headlight part.
See if you can borrow a fuel pressure gauge and get a reading.
Administrator
Glad to see you got it fixed, and thanks for not doing a drive-by!
That connector behind the battery seems to be a common issue on the 95s.
1 - 5 of 5 Posts
