Could that cause it not to start?AstroWill said:Could also be the damper/pulsator in the tank leaking. That would cause it not to hold pressure.
Yes. If the pulsator is leaking, the pump can't provide enough pressure to the injector to fire the poppet valves.WildBorego said:Could that cause it not to start?AstroWill said:Could also be the damper/pulsator in the tank leaking. That would cause it not to hold pressure.
The original spider as leaking all over so I would guess that it can hold enough pressure but your right I got some more parts to get lolLeeann_93 said:Yes. If the pulsator is leaking, the pump can't provide enough pressure to the injector to fire the poppet valves.WildBorego said:Could that cause it not to start?AstroWill said:Could also be the damper/pulsator in the tank leaking. That would cause it not to hold pressure.
But if one spider has a crack and the other leaks on top, fix that first.
thanks..Leeann_93 said:Yep, that's it.
I'll take It for a test drive maybe tomorrow night but I know I gotta change the oil asap!Leeann_93 said:That spider looks great.
Turn the key and it starts is a wonderful thing.
Pouring rain tonight so I can't change the oil or go for a test drive.AlpineVan said:Im glad youre getting it worked out!
