Hi I have a 1986 astro allegro motorhome. What I need to know is if you are running A/C at normal and you switch to Max does your astro fan blow stronger. On most cars I am familiar with When you pur it on max that is in fact recirculate which shut off outside air and the fan speed seems to go up. On this model should it do the same.
Thanks in advance for your help.
Charles
Charles
