1 - 4 of 4 Posts
The compressor clutch wont egage. I tried to jump the low pressure cut off, and it still wont turn on. The system has a charge.
Van, 95 Safari AWD. I cant find therelay or ac control module. no fuse block on the firewall.
Any help?
Did you find the problem?
I'm having a similar problem (no power to the low pressure or the clutch).
Anybody know which relay is for A/C (have two right up front & one farther back in engine compartment)
Thanks, Dave
Discussion Starter · #4 ·
I took it to the shop. First trip cost me $800. They replaced both preasure switche, and the controls in the dash. Then I had to go back since the line to the rear had a leak. That cost a few hundred more. Then the low pressure switch was acting up again. But I was abe to bend back in the tabs and make a good conection again.
So If ya get to a junkyard I would recomend trying to get dash controls to try if you can get them cheep. Mine was dealer for $300
1 - 4 of 4 Posts
