'93 Astro LT Ext w/ FE3 (RWD), 7 Passenger, Dutch Doors, Med Teal, 4.3 V6
I had the battery tray out, which required me to disconnect the e-brake at the pedal and pull it through the fire wall. I disconnected the two wiring harnesses on the engine side in that area. There are a bunch of wires around the e-brake pedal. I'm sure I put pressure on some of those wires when disconnecting the cable.
I have checked the (one) 25 amp AC fuse in the fuse block and it is good. I disconnected the two harness connectors, filed the prongs and added dielectric grease. Still no AC. I giggled various wires with the engine running and the AC on and the compressor never kicked on.
Does anyone know of a likely problem or other quick things to check?
(FYI, I also messed around with the fuse block in the engine bay trying to find a water leak.)
(93 LT RWD with rear air) AC worked great before this.
Thanks!
Thanks!
