When I turn the A/C on my van feels like it is going to stall. There are no secondaries (codes or Lights). I do not know if the A/C is actually causing the problem or amplifying it. I suspect it is electrical ( Ignition) or has something to do with the vacuum. I did have a problem with the A/C defaulting to defrost mold.I found a broken vacuum line and replaced it. Now it works fine. I'am hoping somebody can point me in the right direction for the rough idle.
Thank You
Rick 38
Thank You
Rick 38
