Do you struggle with astroholism? You're not alone.
The 'Twenty Questions' that helped me decide that I was astroholic. Take this 20 question test to help you decide whether or not your have an astroddiction.
Answer YES or NO to the following questions.
What is your score?
If you have answered YES to any one of the questions, there is a definite warning that you may be an astroholic. :think:
If you have answered YES to any two, the chances are that you are an astroholic. :shifty:
If you answered YES to three or more, you are definitely an astroholic.
(The test questions were not used at Johns Hopkins University Hospital, Baltimore, MD, in deciding whether or not a patient is an astroholic).
Remember if you, or someone you care about, is struggling with astroholism, or even mild cases of astroddiction, you've come to the right place. :romance-grouphug:
- Do you lose time from work due to your van?[/*]
- Is your van making your home life unhappy?[/*]
- Do you work on your van because you are shy with other people?[/*]
- Is your van affecting your reputation?[/*]
- Have you ever felt remorse after working on your van?[/*]
- Have you ever got into financial difficulties as a result of working on your van?[/*]
- Do you turn to lower companions and an inferior environment while working on your van?[/*]
- Does your van make you careless of your family's welfare?[/*]
- Has your ambition decreased since taking ownership of your van?[/*]
- Do you crave your van at a definite time?[/*]
- Do you want your van first thing in the morning?[/*]
- Does your van cause you to have difficulty in sleeping?[/*]
- Has your efficiency decreased since your van came into your life?[/*]
- Is your van jeopardizing your job or business?[/*]
- Do you work on your van to escape from worries or trouble?[/*]
- Do you work on your van alone?[/*]
- Have you ever had a complete loss of memory as a result of your van?[/*]
- Has your physician ever treated you for mental anguish over your van?[/*]
- Do you work on your van to build up your self-confidence?[/*]
- Have you ever been to a hospital or institution because of your van?[/*]
What is your score?
