1 - 2 of 2 Posts
I tried to replace the front coil springs. I had the front end dissassembled, had one coil spring out with a rented spring compressor...and then opened the box I got from NAPA...they were the wrong springs! The part number on the box was right, but the springs in the box had a smaller ID than the originals, were a smaller diameter, and even shorter than mine! The good thing is now I know the springs are OK...unloaded my springs are 15.5 inches...which is what the new ones were supposed to be.
So, a hand injury from a loaded spring THWACKING me with the lower control arm, a whole day wasted in the hot Florida sun, and nothing but a broken lug stud to show for it...GRRRRRRRRRRRRRRR!!!
I guess I'll bring back the cheap NAPA shocks too, and order some heavy duty ones...maybe Ranchos.
I couldn't even install the shocks, since two lower bolts broke, and the hardware stores were closed by the time I had the front end reassembled...GRRRRRRRRRRRRRRRRRRRRR again!
An Overland front end body lift spacer kit is looking better and better!
BUT!!! On the lighter side, the positive side, Brian's "Bright Side of Life"...lmao (gotta love Monty Python!)...I DID discover that my Astro has all new brake rotors, new pads, new calipers, new rear drums, new shoes and hardware, and all new brake lines. Some previous owner did all the brake work not very long ago! They did bypass the ABS system, so it has standard brakes, but its all good to me! I don't like ABS anyway!
Where the heck is the torsion bar adjusters on this thing? From all my reading, I thought even the 2WD versions had front torsion bars...is it just the 4WD versions that have torsion bars?
I know this is a duplicate of another post, but I figured it deserved its own thread.
Kev
Only the AWD's have torsion bars; 2WD's have coil springs.
The torsion bars actually replace the coil springs for front suspention. Thus, by replacing(or attmpting to replace) the front coils on your van, torsion bars are nowhere to be found.
1 - 2 of 2 Posts
