All Astro/Safari vans bolt the frame using the same patterns, same boltholes and so on. If you plan on going off-road the 98 and older AWD transfer is better, however if you plan on going with a 4x4 transfer then the drive shafts for the 99 and newer swap right in with the 233c transfer case. I put a 98 AWD frame under my 89 RS.
