Yeah. Just a low air in one tire can cause that symptom too.
Forgot that people are not aware of this.
If you want to be absolutely sure if the wheels are turning the same amount for travel the second article there gives you the most accurate way to tell and you don't have to put it up on a rack. You do need enough space to run straight and flat however.
I found that the amount of load you had can affect this. ie more weight in the right rear will "flatten" the tire ever so slightly, and affect the measurement. Not usually enough to cause too many problems, but I did find that the easiest check, especially if you are on the road (like I was in UT one time trying to figure it out before I came home) I used chalk on the out side of the wheels and drove the van in a straight line in a flat parking lot. figured out that one tire was low. I had a compressor in my van (always have one actually) so I adjusted the pressure on the tires and got them all to roll the same amount and problem went away.
