Here we go again...
A few days ago I was informed that the van was knocking. It was dark so I went out just to listen and figure out what was up. It was definitely knocking but it didn't sound like an engine knock, so I was thinking that maybe the flex plate had broken or a TC bolt had backed out. It sat for a couple days until it was warm enough to crawl under it. I found transmission fluid dripping from the torque converter cover. After taking the cover off we didn't see anything obvious so we knew it had to come out, again.
The first problem became obvious when we drained it and coolant came out first. Then at the back we found that the transmission mount bolts and one of the rubber disks were gone and the other is dry and rotted.
Once we had the transmission out the source of the knock was obvious, there was a a fairly deep groove on the hub of the torque converter. I forgot to take a picture because we were in a hurry to get to the shop to get a new one before they closed for the weekend, and we needed it for a core.
On a side note, it was one year ago today we put it
back in after the cheap Chinese forward sprag exploded. We had a bad wind storm and a huge wildfire that burned an entire neighborhood just north of us, and the Discount Tire a couple blocks up the street collapsed.
At this point I'm not sure what was cause and what was effect. I have a new radiator, torque converter and gasket set. I'm waiting on new clutches and band and a bushing set. As soon as i get it apart I'll make the decision on steels but since it is fairly new I think they are probably ok to reuse. I'm also hoping that just the pump bushing is destroyed and not the pump itself. We'll see.
I can't seem to find the rubber disks for the transmission mount so I'm thinking about getting some of those hard rubber vibration dampers they put under washing machines.
Fun fun fun...
