1 - 5 of 5 Posts
· Banned
Hi guys. My front blower motor was chirping and squeeling, so I took it out, sprayed WD40 on the bearings and put it back in. When I turned it on, it didn't work, and blew a fuse. Now it just doesn't work at all. Did I short it out with the WD40????
· Premium Member
Do you know what the WD stands for in WD40.
Water Dispersion.
I've used WD countless times and then put power to the circuit and never blew anything up.
You've probably got a bad bearing in there so the WD40 will only quiet it for a second to a short while before it starts making noise again.
1 - 5 of 5 Posts
