1 - 3 of 3 Posts
Back at the start of July my 97 Safari's A/C Compressor clutch went, and eventually the compressor siezed, I am to cheap to fork out the 600 bucks for a new one, and didn't trust any of the ones I found at the local scrap yard, so the 100 dollar solution was to buy the non AC idler pully (which sadly cost 75 bucks from overpriced GM) and a non AC belt, bolted in the pulley, put on the new belt, and voila, working van, but without the AC. Just thought somebody might like that low cost solution. also, wonderin if doing this will cause any problems with timing, the computer, or the heating system, cause it gets mighty cold up here in Canada in the winter, can't survive without heat
Discussion Starter · #3 ·
I actually found a pulley here in Canada for 24 bucks at a local parts store, but alas, it does not come with the mounting hardware, which is just a bolt really, and I couldn't find one at the junk yard. I needed my van asap due to having no vehicle, so I had to swallow the cost and buy the pulley with the 50 dollar bolt at the GM dealership.
1 - 3 of 3 Posts
