I have a '94 chevy astro (I think stats are in my sig, if not I'll update it). The other day, it was acting weird -- the wife was driving it, so I have a very vague description of what happened. Basically, the steering wheel is adjustable up/down, and the left side seems to have a component that broke off. The left turn signal was not working properly, and the van would not shut off.
Upon investigation, a part came out of the steering column through the back of the turn signal. It managed to push its way out, so i grabbed the broken part and a rather large solid metal nut of some sort that came out.
Now, the steering wheel is higher than it's adjusted for, but if you press on it moderately, it will return to the position it's supposed to be in. If you try to turn the key off while in the relaxed position, it will not work and you can remove the key while keeping the engine started. Actually, you can't even turn the car off even by putting the key all the way in the accessory position. On the other hand, if you push the steering wheel down to its correct position (the position that i presume this part would hold the steering wheel in), turning the key off and all other operation works as intended.
I have no idea how to fix this, but i really do not have any funds to get it repaired. I'd really like to fix it if i can on my own, but I am very afraid I will get myself in too deep and end up with a steering wheel that doesn't work at all, as opposed to one that works with the proper persuasion.
Has anyone heard of this problem before? Is it common? I suspect that the reason for it is the van is high up and shorter people such as my wife use the steering wheel to pull themselves into the seat. I've ask her to not do that anymore, but who knows if she will really be able to not do that =\.
