:banghead: I had to swap out my radiator today.The radiator I bought came out of a 98 in the salvage yard.I can't return it so I have to make it work.All of the fittngs and hook ups were the same except the trans cooler lines.The ones on my 99 are larger in diameter than the ports on the 98 radiator.Can I just run a large trans cooler and bypass the radiator trans cooler?Also do I just cut the fittings off the trans line and slide the new rubber lines over them and use hose clamps?Sorry for the dumb questions but I really need to get it going.Thanks
