Bracket? This should never happen with the top of the radiator shroud installed. Unless perhaps you have some really bad motor mounts. Or the fan clutch is coming apart, or loose. One is a heater hose, the other is a top radiator hose.
Sure sounds like the last mechanic is to blame. Good reason to do your own work if at all possible. Personally I am better if I mess something up than if I paid someone else and they messed it up.I did have a mechanic install a new heater control valve a couple months ago. They would have been the last ones to handle that hose......(this just dawned on me as I'm writing the last paragraph!)
I thought there maybe was a bracket missing. It didn't even occur to me that my mechanic installed this wrong on the last repair!
I try to here and there. But sometimes I don't have the time or knowledge. Hoping my mechanic will fix this for freeSure sounds like the last mechanic is to blame. Good reason to do your own work if at all possible. Personally I am better if I mess something up than if I paid someone else and they messed it up.![]()
They should if it was recent.I try to here and there. But sometimes I don't have the time or knowledge. Hoping my mechanic will fix this for free![]()
Your a lifesaver. Thanks!
