Hello!
I recently installed a 2002 front differential into my 1995 Safari, because it had a more desirable ratio. I had to get CV's for a 2002, as the inner CV end is different from 1995-2002. I replaced the output (CV axle) seals on the differential as well.
The main point of the thread is I'm having a lot of issues getting the differential to stop leaking from the seal where the CV comes out. At a glance it would look like the CV isnt seating all the way into the differential, but this is as far as i can get it in. I've assembled it on the bench and verified that the stub shaft is bottoming out in the CV, so there is absolutely no way it goes any farther.
Does this look right to you guys though? Am I working with defective parts here? Please let me know what/if im doing wrong. I would really appreciate some photos of this on other vans, as I cannot find much by searching.
Thanks in advance. At my wit's end with this issue.
PS in my photos everything looks dry but thats only because ive wiped it from dissassembling and reassembling it so many times. the driver's side was begining to coat the whole underisde of the van in diff oil, driving along like this.
