My 2003 Astro has had many problems with door locks. I replaced the doorlock actuators in both front doors because they were sticky and would not always operate. That solved those problems. The locks sometimes switch on/off so much they sound like jazz drumming.
I traced it to the rear liftgate switch; press gently just enough to engage the switch and all works. Press too hard and all locks malfunction for a period of time. Generally, it locks all doors instead of releasing the liftgate latches. Disconnecting the liftgate doorlock actuator doesn't stop the malfunction of the liftgate switch.
I checked partsavatar.ca for the doorlock actuators, and it is confusing to say the least. For right rear doorlock actuator they list the same as front door actuators but they are distinctly different. I checked with the manufacturer (Bluestreak) and they list it too. I sent photos of the actual part but they claim their part is certified to fit. But it obviously doesn't. Wtf? Did GMC have variations in the right rear doorlock system? I doubt it. If anyone can shed light on this I would be grateful.
Partsavatar.ca is incommunicado about it. I've contacted them numerous times.
My current hack to make it usable follows: disconnect rear right door actuator while unlocked. It can't lock me out that way but it can still be secured by the liftgate lock system which overlaps the two lower doors. Then I pulled the inside trim on the liftgate to access the latch device to manually open the liftgate. A bit inconvenient but I can't get locked out by my possessed lock system. I will work out a manual system with trim in place next, probably a pull string. The other three locks have manual keylocks and two still work.
Anyone have info on removing the liftgate switch? It looks difficult. I got the rear windshield wiper out but am stumped how to get the switch out. Maybe just try harder.
Van is lifted, 4x4, with winch, woodstove, fridge/freezer with solar to lithium battery, tire carrier on rear 2" receiver soon to be on custom front receiver. Still needs sauna, hot tub, and billiards table.
