My door handle finally broke...looks original, so 17 years use is not bad. This site is pretty amazing to get info from, and there has been a few really good threads on door handle replacement. I don't think I'm adding much new to what is already on offer on the site, but hopefully can show a complete replacement with some rough measurements to possibly help someone else. It's also nice to give back to the forum community.
I decided to do the drilling method after spending a few hours at a scrapyard (junkyard) dissecting donor vans. Thought it would be easier then taking the plastic trim off and possibly have something else break.
Tools used:
1) 1/4 ratchet + extension + universal joint + 10mm socket
2) Long flat blade screwdriver
3) Long needle nose + long bent nose pliers
4) 10 mm long spanner (wrench)
5) Torch (flashlight)
6) Coloured pen
7) Tape measure
8) Masking tape
9) 1" spade drill bit
A) Mark and drill a hole roughly level with the top bolt on the door handle. I used a 1" wood spade bit, not ideal but only $6.50, so a cheap buy. 1" fits the plastic cap perfectly. I missed the latch by 1/8" so worked out well.
B) I used a 10mm spanner (wrench) to undo the top nut. A bit of careful work and the bolt can be lifted out the hole.
C) Use the screwdriver to pop out the plastic cap and undo the bottom nut using the 1/4" ratchet accessed through the bottom (factory made hole). Then the handle can be removed from the door and the rod separated from the handle using the screwdriver.
D) Use the masking tape to cover the paintwork. Mine was already scratched from when the handle snapped off, but I didn't want to make it any worse.
E) I bought replacement driver and passenger handles from the scrapyard for $6 each, just in case. The passenger (left) is a GM part, the driver's (right) has Taiwan stamped on it and is noticeable lesser quality and doesn't open as smoothly. I will probably replace this when I next visit the scrapyard.
F) Insert the new handle from the front and I found it easier to connect the rod once the handle was in place. I used the pliers to line it up and the screwdriver to "snap" it into place.
G) The nuts can now be fitted using the same technique for each nut, top and bottom. A plastic cap from the scrapyard can be inserted into the hole and it looks like a factory finish.
H) Some rough measurements on where the top hole is. This was level with the top bolt and missed the door latch.
It took me a while as even with the hole, it is a fiddly job. I did several runs to the tool shop to get tools etc but hopefully now I will be quicker if I have to do it again.
Thanks for such a great forum.
Not sure why some pictures are sideways. You get the idea though.
Tools used:
6) Coloured pen
7) Tape measure
8) Masking tape
