Shipped only. I was going to have some fuel injector bungs welded to it and some fuel rails made for MPFI injection.
Seems they are getting harder to come by these days, everyone is out of stock.
Asking $350obro
Edelbrock Performer Vortec 2114 V6 Chevy Intake Manifold Edelbrock 2114: Performer Vortec V6 Chevy Intake Manifold - JEGS High Performance
Chevy 200/229/262ci 3.8L/4.3L 90° V6
Based on the powerful Edelbrock Performer 90° V6 intake manifold (350-2111), this dual-plane intake is designed for the engine swap market utilizing 1985 & later Chevy 200-229-262 c.i.d. (3.8L and 4.3L) V6 engines with Vortec heads. With this new manifold, rodders can take advantage of the higher flow available with the Vortec head design. This Performer VORTEC V6 intake manifold has provisions for external water bypass and may be used on either Vortec blocks or 1995 and earlier blocks. Designed for use with Edelbrock Performer Series 500 cfm carbs, it accepts late model waterneck, alternator, HEI and air conditioning.
Installation Notes:
  • Accepts late model water neck, alternator, AC, and HEI (provisions for external water bypass)
  • Port Exit Dimensions: 2.05" tall with slanted side walls
  • Manifold Height: (A) 3.50", (B) 4.18"
  • Carb Pad Height: 3.84" Click here to determine carburetor pad height
  • Recommended Intake Gaskets: GM 065-89017866
