I raced a turbo Grand National with my 502 supercharged G-series van back in the day. Although I had some serious back and forth traction issues the entire pull (van was rocking taking turns burning rubber).. I would have loved to see the look on his face as I pulled away from him regardless. The ladder bars (and Ford 9") I have never got installed as my interests and priorities changed. This stuff is still hanging in my shop.
I'm a BIG fan of sleepers.. and BOOST.
I still own 3 supercharges... considering putting a small one on my 92 (which will easily fit)
This is the easy way to make boost, looks good..
I had it on my 400 small-block (torque monster) until I built and put in the even bigger 502.
But my 92 V8 Astro van is my gig van, goes on the highway regularly, and needs to be reliable. I've gotten spoiled not breaking things... despite that it can easily burn rubber down the road.
There is room to go "UP" in the engine compartment, but not much else.
Lift the AWD van and this solves multiple issues as well.
There is more than one way to do things.
The 400 (often overlooked) is essentially a 383 stoker, with bigger pistons.
The 383 uses the 400 crank (lol) but only 350 bores. Give me big bores AND stroke.
My 400 was supercharged big block power in a small block package.
Of course a 500 cubic inch supercharged big block is PURE insanity.. especially in a VAN.
The fat tires, pounding rumble, and blower whine usually gave me away.
Beating turbo and supercharged cars was where the real surprise and fun was.
Have you considered the AWD system (transfer case and weak front differential) may not handle excessive power well. The RWD is a probably a better candidate.. but GM did build the Typhoon.
BIG insane power is fun.
Personally though, I'd never waste my efforts with a little V6 (pushed to it's limits) when a V8 can do the same job without even trying. But that's me. To each his own.
Turbos (like superchargers) are fun.
Sleepers are a BLAST.
Have fun!
(I think you're going to need to buy a van first)
Both of these were new crate motors when I bought them...
had them both in my shorty hotrod G-van over the years... 400 and 502
This is how they looked new.. the 400 was eventually supercharged too.
Actually, the 400 is a small block.. SAME exact dimensions as the 350 which fits perfectly fine.BTW, I definitely don't see either of those two beastly engines fitting into an astro van. But it would be amazing to see someone try. Haha.
I have personal photos/videos (from 90's Ohio truckin)
of Blastro when it was being designed and built.
Towing his concept machine around at event showing it off...
Many years later....
PROOF ANYTHING "CAN" BE DONE!!
But I doubt he is driving this to events (or the grocery store) like I did with mine,
which is why my Supercharged 502 won "Best Engine" at "Illinois Van Nationals" back in the day. Blastro wasn't there, but his mid-engine wheel-standing van was. He was very cool about it.. even made me a "personal award" from him too. 502's were also the "new kid" on the block.. mine was a pre-assembled crate motor which I promptly took apart to make it ready for blower. This engine was lowered to cross-frame (with custom welded mounts) to accommodate blower which fit under the dog house and under the hood. Still had the custom dual-din stereo in the dash too.. lol. It was also my daily driver.
Oh I sure miss those days (we all started somewhere)
Here's a video of my van several years prior, when it still had the old 400 in it...
(the young model is my daughter, now with kids of her own)
The dual-quads (in photo) also fit same as single carb in front of distributor, height same as well.
The B&M/Weiand/Holley small-block blowers utilizes a flat manifold which sits much lower than any typical dual-plane manifold. The overall total height difference is just a couple inches... and there is ample room above in van engine compartment. Shorter air-cleaners can be used, but not necessary. These type blowers were designed to sit low under hood. Boost...easily done.
Carbureted big blocks ALSO fit the Astro.. it's been done quite a bit as well. The block is minimally taller and wider, but exhaust ports are angled down at an angle, vs 90 straight out on a small block. End result is about the same.
Yes small blocks are cookie cutter.. been done a lot and easy to do.
I like that, and to me a V8 should be standard in all vans.
If your goal is to go fast with minimal work and expense, this is the option.
Additionally all the accy's from V6 fit the V8.. pulleys, PS, alt, harmonic, even A/C.. all direct fit.
Torque accelerates you and moves you down the road.
If you want something complicated and less common, then the sky is the limit.
Anything "can" be cut, welded, moved, etc.
Turbos are common too.. but a fun option.
Just not sure they are a good fit for the Astro for most people.
But we love the "exceptions to the rule" too.
If you want to be that guy.. we await your van purchase, and build.
