randytfd said:
If you think that the pipe probably isn't at fault what other causes could there be?.I doubt that the exhaust manifold has a crack and I'm not sure about the shape the studs are in.Has anybody else had this problem or something similiar? Im hoping that GM put manifold gaskets on these rigs i know they dont believe in valve cover gaskets anymore they just figure silicone works for everything LOL! What ever would make them shift from a donut gasket setup to metal to metal is beyond me... "if aint broke dont mess with it" I sometimes think this stuff is puposely engineered to have a very limited lifespan so that you have to come back to the dealership everytime something screws up!
I honestly can't tell you what's at fault, I would need to examine your van. I can only tell you possibilities and probabilities. The possibilities are:
-leaking gasket(s)
-broken or missing studs or nuts
-crack in exhaust manifold
-damage to pipe
-leaking at 02 sensor or 02 sensor bung
And I'm sure there are more. But exhaust manifolds do crack, that happens alot. Metal to metal does seal well for exhaust systems, as long as the surfaces stay true and straight. But in the end, to figure out what kind of problem you have, you'll have to look. Look at the exhaust and when you see a black fine powder, that's an exhaust leak.
