So I thought I was in the clear after I got my tweeters nicely mounted with their swivel mount and all where the factory ones were minus the grill covering (putting matching carpet behind them so they look nicer)...
Then I finally got the whole door panel off to find the factory speakers weren't the same size as my JBLs... They are about a 1/4" larger it looks like, and the mounts will not fit my jbls without some serious modification. I am planning on trimming the old mounting bracket I have down and glueing it to the existing one, but I was wondering if anybody has had this problem in the past and had any suggestions before doing so. The other alternative would be to cut two plywood rings and use those as mounting "adapters".
Thanks.
FWIW it's a '98 Safari
Thanks.
