There have been a lot of topics lately on fuel pumps so I thought I would document the install on mu 99 this time.Different year models may be different. Hope this helps someone out in the future.
Step 1- Locate the connections for the flex lines to the pump.You will find them between the tank and driveshaft.Tey are a pain to get to but can be done.You will need a set of fuel line release tools for this step or a right angle pick and lots of patience.They are all three different sizes so they will only hook up one way.No need to label.They may be hidden by the plastic tank shield if your van still has this.Mine was discarded during the last fuel pump install in June!Don't make the same mistake I did buy the GM pump not the cheap one!!!! :banghead:
Next disconnect the filler neck.Then put a floor jack or something under the gas tank.Then remove the 2 bolts that hold the straps up.
By now you have probably said a few choice words lol. Next slide the tank out from under the van to access the pump.
Next unplug the 2 plugs on the pump assembly.Then you will need to remove the retaining ring.I used a right angle pick for this.
Now remove the flex lines from the old pump and install them on the new pump.Some pics of my new pump.
My new pump came with a new wiring harness for the new style connector.Pretty straight forward install.
Now just reinstall and drive :dance: Don't forget to replace your fuel filter while you're there! Now sit back and enjoy a few cold ones :cheers:
