hi all ivgot a 86' astro code z engine th problem is i can start it but wont run long it seems to loose fuel but befor this it had fuel but wouldnt idle unless you pumped the gass pedal i changed the roter cap plugs and leads also the iac valve i think isnt working can you tell how totest the pump a iac valve and how to see if the tbi is working proply ? its drivin me nuts
