Replacing my fuel filter. Going through the steps - remove fuel pump relay, run engine until it dies. Except the engine didn't die. I am not sure how long the engine can run with the relay removed, I'm let it run a minute or two, high idle... but it kept going.
Now the fuel pump makes a high pitched hum/whine when the engine is running. It might get annoying but that is for another day. BUT as I was waiting for the engine to die I could still hear the fuel pump.
1. Am I correct that the reason to pull the relay is to turn off the pump?
2. Did I not let it run long enough?
3. If it is supposed to shut off why doe it still run w/o relay? Only thing I can think of is the got bypassed at some point but I don't see anything hinky and I would think a bypass would cause a whole slew of issues. Alternate theories?
4. What happens if I open the system while still pressurized? I am assuming it sprays everywhere including face, creates a fire hazard etc. Can this be reasonably contained with a shop towel?
Any insight is appreciated.
