Off to a rough start, tank bolts took forever to get out, lots of penetrating oil and torque, finally got both out from passenger side.
I forgot what I was under the van to do after a hitting my head on the transfer case.. I remembered when I hit my head on the leaf spring…
I do have the filler neck disconnected as well as the evap? ( Little black box near fuel filter ) and the wiring harness…
I'm unsure how to undo these fitting on the pump itself.. I bought fuel line disconnect tools, but it looks like there's no room for them in there! Are they pinch fittings?
I'm definitely planning to cut a hole in the floor when my tank is removed later… I'm dropping the tank today just to replace the part that sends to the fuel gauge, and to replace the rear lines so I can get a new fuel filter on.
If and when I need a new pump, I'd rather not go through all this again!
Also, what's this black box on top of the fuel tank? I wasn't expecting it, since I've seen a number of diagrams and photos without one.
Thanks for helping !
