I do not -however, I do know all the frames from all years and models bolt up the exact same way. I also know the newer frames after 94 were beefed up by GM to some extent. And the newer vans use electronic shift of some sort, verses the frame mount linkage for the shifter on the older (pre-95) models. If you still need them, I may be able to get them since my van front end is still on jack stands. Mark
Here you go from my shop manual-didn't know they were there -found them while looking for something else. Mark
