HI. I have a 97 safari AWD conversion van 1st owner
I believe the front wheel bearing/ hubs are about done. However im trying to keep cost down and avoid changing wheel hub assembly.
I searched the forum *possibly did it wrong* to find archived info on the hub assembly with no luck.
Pricing: I've found the hub assembly on ebay new with NO warranty for 150 each
local parts stores want 250+
as for the dealer: well i just spent 180 on tuneup parts only cap rotor wires plugs prob 500 each im guessing for the hubs
230k miles
rebuilt tranny
rear bearings / differential already changed
need tips on:
changing o2 sensor since check engine light says so
servicing / maintaining transfer case
flushing coolant system
adding tranny cooler
finding out what this weird road noise and humming is ( probably wheel hubs but not sure)
230k miles
rebuilt tranny
need tips on:
