1 - 4 of 4 Posts
Ok, I have the dreaded rear air works, but the front is only pushing air into the defrost. It is obviously the same problem that others have had as there are lots of posts on this subject. But I am looking and can not find these lines. Can someone please put up some pics in regards to what IO need to replace and where the heck I find these lines at.
And since it appears that EVERY one of these vans will have the same problem, shouldnt this be a sticky?
If there are already pics posted somewhere, a link would be helpful. I am going ot continue to look, but this is frustrating.
Thanks for your help.
I have posted a bunch of stuff on this problem reid1boys. I'm a bit surprised you haven't found anything.
The first question that needs to be answered here is what year is your vehicle? Thanks.:)
PS: And Welcome to the Forum.:)
Discussion Starter · #3 ·
My van is a 98. I found the vac hose and replaced the bad section by just getting rid if the bad "Middle section" of the hose. Just connected a new hose to both ends of the vac line that remained and presto, front air ducts were working.
I took some pics and am adding them to help anyone else that comes by this. I guess I just didin look hard enough if you added pics before.
Thanks
These pictures so the locations. I had to remove the air cleaner and the air cleaner assembly to get to the location where the vacuum line goes across the engine. That is one of the pics. Hope these help someone.
Those are great pictures reid1boys,thanks.
Very common problem with these vans.:)
1 - 4 of 4 Posts
