1 - 7 of 7 Posts
I heard @CopperFiremist might know how to get motor mounts made? I had a mechanic here in KC stuff a '08 Tahoe V8 in my '92 Safari, but he didn't modify the pan so im assuming the angle the motor is currently sitting at is causing all the vibrations. Also heard the H3 Hummer oil pan will bolt right up and work for clearance? Anything will help! I can't get motor mounts anywhere and can't find a competent Mechanic here... THANK YOU!
Discussion Starter · #3 ·
That's what i'm trying to nail down, I've seen several in different places but don't know exactly which one will work. Its a 4.8 LS V8, its the same block as the rest so not sure why this is so hard to get mounts made/found.
Not sure which build thread he's referring to, but I found these LS1 / V8 swap & mounts stuff:
Both from Copper...
Discussion Starter · #7 ·
Both from Copper...
saw those, i don't have the shop nor skill to pull off a custom pan and a custom diff mount.
Font Rectangle Handwriting Slope Pattern
1 - 7 of 7 Posts
