What brand of Hitch did they put on your Astro?
Right, that's what brought me here tonight - looking to select a two-inch receiver hitch for my 99 Astro LS Ext and have found several vendors, brands and models within brands with prices ranging from a low of $125 (Reese Part #: 37042 - Drilling Required ) to over $370. One (Reese) reads " Will Fit With Full Size Spare Tire Stowed Under Vehicle" which I think is an important feature. Also, some do not explicitly state that the hitch does NOT interfere with the stock spare location and I think I only found one hitch that requires moving the spare.
Basically, I will be hauling a small trailer with a 4x4 on it. However, I hope to be able to haul my 5' wide Kubota b7800 tractor with FEL between our two properties (80 miles or so) and that may require a tandem axle trailer. The van should handle the load. Want to be sure that saving a few dollars now doesn't put me at risk later!
It seems that the least expensive model is a 'multi-fit' affair (hence the required drilling) and the 'bolt-on' models are sixty to eighty dollars more.
I'd like to know what I'm getting into if I 'go for' the 'multi-fit' but have yet to find a video of the installation of such a hitch on an Astro or Safari.
Any help??
