X2.Some stock set-ups do rely on back pressure for their performance.Headers should be the last thought AFTER all the other mods are in place.Quick fixes for performance are just that in results.Everyone thinks incorrectly that just by hanging on a cad or muffler they are now in the same place as a guy who knows how to smooth flow a induction system.(head work done,cam that matches,rear end ratio that capitalizes on peak torque/HP ranges,matched injection system,etc.)I just take moves like a exhaust cure alls as a lazy mans fix or one that is totally misinformed. :2:
I want to explain my self alittle better.The real question is does headers on a stock set-up work,at idle-nope.So where do headers really start to work??.What RPM??.How about at 2500 RPM??.Well truthfully not much there either.How about at 3500 RPM-just starting to have somewhat a effect,about 2% or less.My point is like any other engine these are air pumps.Air pumps that need a balanced in and out.Stock air ratios run out of fuel/air by the time headers have any effect.In fact header "could" create a lean condition which is not good for stock engines.The ECU feels it needs to put in more fuel and at best it is still within the limits of the stock injector system which is not enough.That headers also need to have a active 02 sensor.Also there are limits to the stock cam and kit in these engines.So by the time you have reaped any real benefit from headers and their scavenging effect,you have run out of RPM.Got to be mindful that headers are truly for HP and because of that their effect is in the upper RPM ranges.The concept is HP is a peak in the upper RPM ranges.Also small C.I. engines by the nature of their size have a HP peak in the upper RPM ranges.So if you want to get to use say 5 to 7 hp at best.............Well I think you can see what I am saying.No giant killers there.
The idea of a tune on a engine is now and forever will be big picture.Total concept and not just one pc of it.
What is so disheartening to me is a guy that just because it is louder thinks it has more output and walks round with his chest pumped out having done only one thing.It is his mind game that I really don't want to be apart of.Again just my :2:
I realize this is an old post. But it is really wrong. Saying headers don't work on a stock engine is wrong on so many levels simply because it assumes they are ALL the same. Tube length, diameter size, and header configuration all play a part. And I am not sure I have ever seen a header not make power or worse lose power.
