1 - 6 of 6 Posts
how much should an ICM cost? AC delco? i see bunch of no name likley chinese stuff on amazon.
Probably the cheapest place to get the ACDELCO OEM part. Not a part I've replaced so I wouldn't know if getting OEM is worthwhile. Spark Plugs are the only OEM parts I've bought for my van so far.
Administrator
I have seen them online with the ICM/coil/bracket all together as well. Just depends on what you want to spend and if the brand matters to you.
Discussion Starter · #4 ·
do the billet distributors have one? how much are billet distributors?
01 Astro Cargo RWD, 97 Astro Mark III AWD
The ICM is not mounted in the billet distributor like the old HEI ignition.
It is mounted on the same bracket as the coil.
Administrator
1 - 6 of 6 Posts
