Before I started a mechanic told me to go to Harbour freight and buy the engine hoist. Instead I bought the 4 ton bottle jack. Couldn't have done it without but the hoist would have been much easier.I had mine apart and I honestly think using an engine hoist to lift the engine just enough is the best way to do it.
HUH?????I had a hard time with this project and ended up removing a lot of things that weren't necessary,
like the passenger and drivers side mirrors.
I pull engines and transmissions and enjoy the work, but changing the motor-mounts in an AWD is the one job I passed on, and paid someone else to do it. It was when I couldn't even see them.. I passed.It's a lot of work for a vehicle of questionable value. I spent the entire project wondering why I just didn't keep driving it.
I didn't really remove the mirrors but wished I would have after hitting my head on them a few times. As far as the space I gained between that tube and that pan it was only about 3/16. Not sure if I did things right using duralast parts but I do wish I would have added spacers somewhere. I also replaced the transmission mount and had to lower the crossmember for that.HUH?????
Not sure why you'd say you removed them when you actually didn't.I didn't really remove the mirrors but wished I would have
I've never had to lower the crossmember to change the trans mount.. just jack the trans up a little and it comes right outI also replaced the transmission mount and had to lower the crossmember for that.
Just said it as a joke, sorry for your confusion. My Canadian friend knew that wasn't a steering link but on this site it's the best way to get a response. Sure glad your here.Not sure why you'd say you removed them when you actually didn't.
Mine I just fold in
what he said.Wow!
Yep. Should never, ever touch.Definitely more than that.
