1 - 4 of 4 Posts
You'll need 4 1/2 to 5 1/2 liters of ATF.
As far as plugs go, use AC Delco platinum plugs.(can't remember the number)
13 quarts is listed capacity I believe for us americans, and the plugs should be cross refable by an auto parts guy (use Delco plats like came in it) if you're below 100K i probably wouldn't mess with em honestly.
13 quarts is the TOTAL capacity of the trans. When dropping the pan, you only lose about 5 quarts.
1 - 4 of 4 Posts
