1 - 9 of 9 Posts
I recently decided to flush the coolant system on my 1995 Chevy Astro van. I ran a chemical flush through the engine/radiator for a couple days and have been draining and refilling with distilled water for the last week or so. The water is getting cleaner, but I am only getting about 3/4 of a gallon out of the radiator each time I drain it. The owners manual states a capacity of 16 quarts so how do I get the rest out? How can I achieve a 50/50 antifreeze mix if I can only drain less than 1/4 of the fluid at a time?
My van has rear AC. I have been draining coolant via the plug on the radiator on the passenger side of the van.
Discussion Starter · #3 ·
On each side of the block there is a drain plug. Take them out poke a coat hanger in there to knock the crap out.
Ah I see, that makes a lot more sense. I assume I should use some thread sealer or something when I put those plugs back in? Do they need to be torqued to spec?
Super Moderator
No they are a pipe thread no sealer. Wouldnt hurt if you want to tho. I don't know the spec I go by good-n-tight
Premium Member
best way to fully clean the coolant system: after its empty add i cup of cascade dish washer powder to a gallon jug fill it with warm water shake it dump into closed system then fill with water. let it run for about 45 minutes with heater/s on full.
Then drain it as fully as possible and run a hose in it with engine running to allow it to clean it out. Then drain and refill with 50/50. But do not fill with tap water use distilled water. Tap water has minerals in it thet will clog the system.
Administrator
Also, you don't really have to drain the system to get a proper mixture. Every time you drain some diluted antifreeze and add 100% to it, you will increase the percentage of antifreeze to water.
You can pick up a mini tester for like $1.25 to see what level of protection you are at. https://www.walmart.com/ip/Chaslyn-Small-Anti-Freeze-Tester/16927981
Exactly. Personally, I don't get OBSESSED with this stuff. It's just not worth the extra trouble. After fully flushing a system with water... I drain what comes out naturally, add a gallon of antifreeze, and if there's any room left, finish topping it off with distilled water. I know it's fairly close to a 50/50 mix. Close enough for me.
Discussion Starter · #8 ·
Wow that's really cool. I figured I would have to drain the whole system to be able to know I had a 50/50 mix. Definitely gonna pick one of those up, very cool little tool to have.
Discussion Starter · #9 ·
That makes sense. I just did almost all the other fluids and am pretty green when it comes to working on cars so I wanted to make sure I could do it right. Plus I use this van for road trips and don't want my coolant to freeze in the lines overnight somewhere because I got the mix wrong.
1 - 9 of 9 Posts
