1 - 20 of 22 Posts
It's easy to change the upper ball joint. The upper bushings isn't too bad. The lower ball joint requires a press. The lower bushings require a spring compressor.
I wouldn't do anything beyond the upper ball joint without air tools.
The tools I use for the job are an air impact hammer, 1/2 inch impact wrench, big hammer, two floor jacks, two jack stands, a ball joint press (I have the otc 7249), a spring compressor, and a bunch of hand tools.
1. jack up van and put it on jackstands. I want both front tires off the driveway.
2. remove tire and caliper. Hang the caliper off of something with some plastic ties.
3. remove rotor
4. This step is probably different for some years. On a 97 there's a sensor mounted on a plastic disc behind the rotor. It's mounted to a backing plate made of sheet metal. The sensor if riveted to the upper control arm and I believe the backing plate too (GM nipple heads). One nut joins the plastic piece to the sheet metal piece. Leave it. The others go through both pieces and attach them to the spindle. Remove those and stick the whole thing over the upper control arm. You will also have to follow the sensors wire back behind the upper control arm where it plugs into another wire. It's pretty easy to disconnect by feel which you will have to do before you remove the upper control arm.
5. use impact hammer to knock four bolts off of upper ball joint.
6. remove castle nuts from upper and lower ball joints
7. remove tierod from steering knuckle.
8. You might a well detach the sway bar link now too if you are going after the lower bushing. You might as well change the sway bar link too but you don't have too.
9. Knock the ball joints out of the spindle (the big hammer works good here but I'll leave the tool choice up to you) and remove the spindle.
10. The upper control arm is held on with two bolts. If you pry the upper arm up you can see the two bolts. They have nuts on the other side which you cannot see but you can get a wrench to them. Using the tool of your choice (1/2 impact wrench works) loosen them. There are these things called shims between the control arm shaft the the mount point on the van. Reach in and pull them out. You want to put them back the same way so try to figure out how many are on each bolt and put them someplace where you will be able to remember how they came out. Once you have the shim packs out finish removing the nuts from the two bolts and remove the upper control arm.
11. At this point I would get my otc press out and remove the lower ball joint and install a new one. You may want to just remove the lower arm and bring both arms to a shop for these steps but that's up to you.
12. place a floor jack under the lower ball joint. Make sure it's holding it.
13. Remove the shock.
14. Take your spring compressor. I use this: http://greatnecksaw.com/product_info.php?pName=coil-spring-compressor&cName=undercar-shocks&osCsid=498d5f83628b4c43b5e8ba5d25ee2dc8
It's a OEM 27035 if the link doesn't work. Don't try and use the cheap ones they sell at advanced auto or the external ones they use for struts cause this ain't no geo spring. Using the tool of your choice (1/2 inch impact) compress the spring until it is loose between the control arm and the shock tower. At that point lower the jack stand and remove it. Now you need to keep in mind that there's a whole lot of energy inside that compressed spring so don't put your face or any other part of your body over the ends of it, don't let the kids play with it, etc. etc....
15. Remove the two lower control arm bushing bolts.
16. Remove the control arm.
Now we have both control arms off with the upper ball joint off and either a new or the old ball joint on the lower control arm. You can find a shop to press the bushings and lower ball joint off and then press new ones in. I would take my impact hammer and start pounding the old bushings out. The lower ones you hammer around the outside edges and they will pop out after a while. The upper ones you take the nuts off the ends (if you can, you have to get at least one off) and then you can hit them from both sides. I've always changed the upper shafts too so I don't worry about re-using those. If you are a really really cheap bastard I guess you will have to figure that out yourself. With the lower control arm bushings you get them in most of the way and then find a hard surface and hammer on the inside of the control arm to try and get the bushings in flush. You may have to turn them over and hammer from the outside right on the bushing itself to get the last 1/8 inch. I suspect a real pro would shake his head at that but I'm not buying a real press to do that. Because I wouldn't be doing this in the first place if I wasn't a cheap bastard after all. On the upper install the bushings into the control arm over the shaft. Then tighten the two nuts asshole tight using a 1/2 inch impact wrench if you got one. You have to stick a screw driver through the mounting holes to keep the shaft from turning when you tighten the bolts. Then you can hammer on the inside of the control arm to set the bushings into place. You probably want to watch someone that knows what he's doing before you try this yourself and you want a really big hammer. I'm not talking about something you would use to drive nails here.
From here it's mostly backwards. The new ball joints have rubber boots. If you look at them they will have a little channel that should be aimed towards the center of the car. That's so overflow grease won't get on your rotor. When you go to put the spring back in you may have to use some kind of adhesive to hold the isolators in place. They are the littles rubber thingys on the ends of the spring. To reinstall them put the bushing bolts back in the lower control arm and start the nuts on them. No need to tighten them until the spring is secure. Put the ball joint end of the control arm on your floor jack. If you used the kind of compressor I use then you have the foot sticking out that should help you put it back where it goes (it's important to do that). Otherwise you should be able to see where the spring sat on the control are and turn it to match. The top of the spring fits over a flange and you will have to lift it straight up over that flange without knocking the isolator off. Then you just kind of tilt it into the control arm (don't knock the lower isolator off either) and have someone jack up the floor jack until the spring is nice and secure. Remove the compressor and re-install the shock and life is good.
After you are all done you will probably want to get an alignment to fix your camber. That's controlled by those shim packs we talked about back in step 10 and it's probably going to be off now. Make sure you go to a shop you trust since most of the tire store techs are not use to having to adjust that anymore and might blow it off.
A few final thoughts.
This is a tough job and I would not consider changing bushings without air tools
Buy a can of penetrating oil like Blaster PB and use is liberally on bolts and bushings.
Springs are dangerous and these vans have big *** springs. Don't even think about using a cheap or external spring compressor.
You have to have a press and a cheater bar to do the lower ball joint yourself.
I'm a computer programmer so if you are following my directions you may get hurt and while I wouldn't like for that to happen you can't say I didn't warn you and now you know I'm not a trained tech either. In fact I may never have even stayed in a Holiday Inn Express.
Unless you think this stuff is great fun make sure you keep the ball joints well greased so you won't have to do it again.
That was a great write-up, Thanks. :)
Very good write up, some other tips. Use a white-out pen and mark the spring to lower control arm. When installing the ball joints, align the cotter pin holes so they are lined up front to back, install the cotter pin back to front so when your in the grassy field chasing rabbits the grass doesn't get caught up in the bent over ends. Anti-seize is your friend. Don't tighten the bushing bolts until the control arms are at ride height. Be safe you all. Mike
spring compressor not needed on GM vehicles they will fal out if you lower the arm however if you want to you can wrap a chain through the spring and nut and bolt it when removing the spring
dont need a compressor to reinstall a GM spring
they are not tall like the ford ones, especially mustangs
we do front suspension and/or steering work at teh shop virtually every day and its no big deal 95% of the time
[remove part
]put new one on
done
sometimes have the owner take it to alignment shop depending on what we had to remove to replace what it needed
bushings are the most difficult other than some balljoints sometimes
we use a troch and sawzall and air chisel to remove them
balljoints we have a real heavy old style NAPa press for the lower ones
but most of the time i will just torch off the ballstud and take a bighammer or sledghammer and put the floor jack under the arm and smack the joint out of thr arm and then put the new joint on the flor jack pad under the arm hole and smack the arm around the hole and it will push the joint up the arm through the hole with the weight of the truck on the arm and jack
works fine usually.
also freeze the joint in the freezer for 30 minutes makes it easy too
same with arm bushings.
the ford balljoints are thew worst and most difficult one time i broke a 1/2" drive breaker bar trying to remove a ford 4x4 balljoint
they are a real PITA often
GM stuff is cake walk compared to some alot of fords
i will never do mustang coil springs or control arm bushings ever again after a 93 we did recently :O
nightmare!! worst ever by FAR
never again!!
almost 400 dollar psecial compressor and we didnt have time to order one so i ended up compressing the springs under the lift arm and using lots of hose clamps to keep them compressed
then sawzall them off when installed on the car
it works..
good luck
  • Like
Reactions: msylvester
I finally got around to rebuilding the front end in my '97 due to a bad ride, much clunking and clattering, and really bad tire wear. Wow that was a big job. It got new control arm bushings, ball joints, and shocks all around. I wish I had some air tools. I ended up taking the control arms to a shop for ball joint and bushing replacement. They did it much faster and easier than I could have. The van rides great now. The lower ball joints were completely shot. I ended up replacing both brake calipers too as the right caliper had worn severely where it slides on the mounting bolts and rattled constantly. Thanks for the information.
Thanks Lump but I have no idea of the grade of the bolt that holds the control arms to the frame. The ones that are pressed or welded into the frame....the ones that the shims ride on for alignment. Its also specific to certain years because I know your bolts are smaller diameter than mine. My stupid manual has the specs for AWD but not RWD. No matter...i set the wrench for 120 and once i got a click i just laid on it. Probably closer to 175ft-lbs now. Those suckers never stay tight.
· Banned
97cargocrawler said:
... Those suckers never stay tight.
Are the nuts and bolts coming loose? (loctite)
Or do you think metal is compressing somewhere else? (shims compressing etc)
Consider marking and loctiting the nuts where they mate with the bolts. Then check again in the usual time and see if they've drifted. Since they're tough to get to, I think I'd loctite them and touch the rear(s) with a dab of paint. Then you could at least use a mirror and see if the paint margins were still aligned. ---___---
Lumptite
The nuts loosen. I retorque them now and then and I'm always surprised how loose they became over time. I would consider loctite but I went the other direction and used anti-seize. I do alignments and remove the control arms more often than most folks and those nuts are such a PITA to remove. They are the type of locknut with the edges crimped, distorted thread. They don't keep their torque and yet once they are loose they are still way too hard to spin.
The shims look ok. I still have the really hard stock steel shims in there.
· Banned
I think those deformed thread locknuts are some of the best holding nuts (holding nuts... :rofl: ).
Let's stick a dab of paint on the threads where they join the nut on the inboard side. Next time they loosen, look first before tightening to see if the nut really has moved. It's hard to imagine that a 120+ ft/lb torqued 12-14mm bolt with a deformed lock nut would back out.
I know this is over a month late but the GM Manual (Helms) for 93 Astro states the following;
Two Wheel Drive
Bumper nuts (rubber snubber) - 90 ft. lbs.(WTH?) (LCA may fall off, but that crucial bumper won't)
Lower control arm to frame nuts - 20 ft. lbs.
Upper control arm to frame nuts - 75 ft. lbs.
Upper control arm to pivot shaft nuts - 85 ft. lbs.
All Wheel Drive
Bumper nut - 24 ft. lbs.
Lower control arm to frame - 125 ft. lbs.
Upper control arm to frame - 125 ft. lbs.
I remember years ago when had access to a front end rack not having to excessively tighten the UCA nut on RWD GM cars. Hope the bolts haven't stretched. That be a heck of a ride if they broke. I have a vague recollection that the UCA to frame bolts have a light spline under the head, akin to a wheel stud but not as deep.
Don
Never did see any sense or logic in changing from a coil spring to coilover.
Just added complexity and expense.
1 - 20 of 22 Posts
