1 - 20 of 72 Posts
Ok, 91 astro AWD... I've changed every sensor except the TPS and the main computer and it still idles rough (rough enough it shakes your brain while your sitting at a light). It will occasionally stall but only going into reverse.
Above idle it still runs great and pulls hard with no oil burn or black smoke.
I also changed the injectors, map sensor, knock sensor, coolant sensors, egr solenoid, cleaned the egr itself (wasn't really dirty).
The van only has 250,000 kms on it so this is really tickin me off.
Put a new wire set, new plugs, new cap & rotor, checked the timing, replaced all the vac lines.
Not sure if it's related but the cruis control doesn't work either but has great vacuum going to it.
I was gonna do a V8 swap but I can't get the mounts for a reasonable price or find a good set of plans.
This is our daily driver and hauls our 4 kids around so if anyone has any ideas please let me know.
Does it blow black(or dark) smoke at idle, or does it have a rich exhaust smell(that really stings your eyes)?
Discussion Starter · #8 ·
Warm or cold it runs the same.
No codes.
Sprayed with carb cleaner... no vac leaks.
The only smoke i ever get is the cold startup blue cloud.
Would a torque converter solenoid also make it idle like crap in park or neutral?
Discussion Starter · #10 ·
No leaks and no stumble.
Compression test shows 140-145psi on all 6 cylinders.
Once you pound that pedal down she takes off like a bat out of hell and pulls strong to 6000rpm without missing a beat.
If someone happens to have a set of AWD V8 mounts to sell or plans top make them let me know... i have a 350 sbc lined up already for $300.. it's a 1994 tbi motor already pulled for me :D
· Banned
Well if airflow isn't the problem, then perhaps it's fuel delivery. How is the pump/filter? I've heard about problems with injector spider assemblies and poppet valves as well.
Discussion Starter · #12 ·
Pumps working but i have not pulled it out of the tank to look at it.
Filter has been replaced.
You'd figure if it was a fuel issue that it would also be starving for fuel in higher rpm's, not just idle.
The spray pattern is a nice clean cone also, no drips.
This one is TBI so no spider assembly in it.
Keep the ideas coming maybe we'll hit on something :confused1:
1 - 20 of 72 Posts
