What should I use guys? Im trying to raise it up a little bit so its a little higher than Van Stock's van. Let me know. Thanks in advance.
Hmmm, are you serious? VanStock's van in his reply looks like a custom suspension. If the red van in your sig is what you're talking about you'll probably need to go that route to raise it "a little higher" than his. If you want a little lift, then I would go with lift blocks under the leafs in the rear and coil spring spacers in between the coils in the front. It's cheap and would probably achieve the effect you're after. Hope this helps.BigJuicyVan said:What should I use guys? Im trying to raise it up a little bit so its a little higher than Van Stock's van. Let me know. Thanks in advance.
