121 - 140 of 154 Posts
2003 Safari AWD
Discussion Starter · #121 ·
Putting some time into the winch mount ignore the van diaper please :)
I am wanting the winch tucked in as far as possible vs hanging directly off the front of the bumper mounts. With the core support gone, you can see the winch is close to the radiator.
It looks a little questionable hanging off those 2 bolts on each side but it has less torque sitting closer in than other style mounts and the sheer strength of the bolts is good.
I'm confident this is good but prepared to have to come up with a plan b.
Automotive parking light Vehicle Wheel Car Vehicle registration plate
2003 Safari AWD
Discussion Starter · #124 · (Edited)
I like where this is going. The front faces of the subframe/bumper mount location would be a liteweight tie-down shackle, move the larger larger shackle mounts closer in, and add a panel to block the space under the radiator to force the air through it instead of under it.
Feedback, comment please! Gonna be too late for your better ideas pretty soon :)
Tire Wheel Vehicle Automotive parking light Car
Tire Wheel Vehicle Car Automotive tire
Lighting and maybe some slots like on the driver side
Automotive parking light Vehicle Tire Automotive side marker light Car
That is looking pretty sharp!
How did you get the slots so perfectly matched?
I can cut and welded, but making those slots so perfectly matched probsbly could not happen here.
Keep up the pictures..Please! :)
· Administrator
2003 Safari AWD
Discussion Starter · #130 ·
Getting the wings fabbed up. I think I will make these bolt on to leave options for a different design in the future and allow me to fit these into my media blasting cabinet to prep for cerakote.
Here you can see the center winch mount cover is bolted onto the front of the subframe - no more clamps! I tapped those existing holes for an M12 and then added a gusset on a downward angle to allow muck/water to drain away.
Might need some turns on the torsion bars... I have pre measurements so will see how much droop there is. I still have the front leveled out with the jacks on each side so not sure yet on the effects of the extra weight.
Tire Wheel Automotive parking light Grille Vehicle
Wood Bumper Motor vehicle Gas Automotive tire
CNC! No wonder it looks perfect.
Now I will not feel bad about pointing out flaws....except I do not think I would find any if I tried.
It looks great!
Rod J
Issaquah, WA
That 'spotless shop' is somewhat sickening:eek:
I cannot even dream of such a clean shop!
It would take a lifetime to undo my messy habits, and I do not have a lifetime remaining.
Did I say 'Jealous'? Maybe not, but I am thinking it!
Rod J
Issaquah, WA
I love that bumper, i also prefer the astro grill with it over the safari
What an inspirational thread!
I too have had issues with mevotech control arms, though in my case it was lower control arms for a 2wd that came with ball joints installed. A test for tightness of the bolts snapped every one of the super cheap and weak bolts included with minimal force. Thankfully i didnt trust the hardware and attempt to drive on those connections.
Maybe you can sell the CAD file.
I am sure some of us would like to recreate the bumper on our vans.
The metal pieces would be expensive to ship to Canada.🙂
2003 Safari AWD
Discussion Starter · #139 ·
It takes some considerable effort to maintain it that's for sure. With all the rust grinding and cutting on the van, then welding/grinding/plasma cutting.... it creates quite the mess. I am learning to keep other benches/tools covered to reduce the cleanup.
One of my "Zen" moments when I need to make progress on a project that I am not mentally prepared for is to start the session with cleanup and organization chores.
2003 Safari AWD
Discussion Starter · #140 ·
I'll look into it. The "problem" is implying the parts will fit another van and I have no other vans to test on.
